주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
LG 440G는 2012년 10월 LG에서 출시한 미국 전용 저가형 폴더 피처폰으로, Tracfone MVNO 네트워크에서 사용됩니다. 모델 번호 440G로 식별할 수 있습니다.
speaker fuzzy sounding can't understand
The ear speaker sounds garbled, can’t understand callers uless i put on speaker mode, can I replace the speaker the I put to my ear on the phone
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Hi jimfetter
Muffled earpiece speakers are almost always caused by dirt/dust getting jammed into the mesh which covers the speaker at the top of your phone. You should try to clean this out with these steps:
  1. Apply tape to the area and peel it off a few times to remove large pieces on the surface
  2. Use a small brush (toothbrush works well) and a small amount of 99% isopropyl alcohol to scrub the mesh clean
If these steps do not fix your issue, you may need to open the device to clean out that area from the inside.
Best of luck!
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
Tried that, .... no difference.
The speaker that I'm talking about is in the lid part that flip's out that you put to your ear, not the speaker phone in the base of the unit. So I can't open the device to clean out that area.
Thanks anyway friend.
의
There should be another smaller mesh area at the very top of your lid where the sound comes out for your ear. If cleaning this area doesn't improve sound quality, unfortunately it might be time to think about replacements.
의
댓글 달기
답변을 추가하세요
jimfetter 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 13
전체 시간: 480
