주요 콘텐츠로 건너뛰기
The Kingston HyperX Cloud II Gaming Headset is a headset designed by Kingston. This device comes with a headset, removable microphone, and an inline USB audio controller and is compatible with most computing devices. Model number: KHX-HSCP-RD
Where would I find a replacement wire for these?
My cloud 2 wire got destroyed recently and i am looking for a replacement cable witch i could sauder back, i would like the original quaility and a for pin so the micraphone would work. The wire had many problems and in the end the jack got brocken in a acident, so i ended up just clipping of the wire from the board and now i have i headset with no wires
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
선택된 해법
Hi @zucky
I have replaced headphone cables in the past with a double ended 3.5mm cable. I just cut off the end and soldered the wires to the breakout board inside the earphone chamber. Here is a quality one I have used that I liked:
https://www.amazon.com/gp/product/B01D9W...
To get the mic portion to work, this will be more complicated. You might need to cut the cable below the mic and vol controls and wire that up to the mic cables inside your headset.
Hope this helps
이 답변이 도움이 되었나요?
점수 3
댓글 1개:
Did you find any difference in the audio quality after the replacement? My biggest worry is getting a dodgy wire so I'm tempted to get like Cloud Alpha detachable wire and snipping off one end to wire it up inside the cups. Any advice?
댓글 달기
@zucky replacement wires are pretty much impossible to purchase separately. you can try and scour the auction sites and look for a headset that is broken other than the cables. Or you could post some pictures of where and how your cable is damaged to see if it is possible to repair. 기존 질문에 이미지 추가하기
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
Mark zuck 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 12
지난 7일: 18
지난 30일: 35
전체 시간: 1,130
