Replacement connector wire for singing chipmunks
Where can I get a new connector wire for two singing penguins? They are supposed to be connected to each other with a thin wire and then respond to each other when the button is pushed. I no longer have the wire. Attached are pictures of the label, ports, and front of the penguins. Thanks for your help.
Update (09/15/2019)
I can’t believe you know what I’m talking about. I am sending two of the best close up pics I could take. If these aren’t good enough, let me know and I will send more. Thanks for all your help.
좋은 질문 입니까?
댓글 6개
lls761 looks like not to many people are familiar with what you are looking for. Post some good pictures of the toy as well as the wire and, if there are any labels, with your question. It may help us to identify the issue and help you resolving it. 기존 질문에 이미지 추가하기
oldturkey03 의
I am not sure if my responses have posted. I will try again. Attached please see pics of the ports, label and the front of the penguins. Thanks for any help you can give me.
[image|1846039][image|1846037][image|1846036]
lls761 의
Trying to repost pics.
[image|1847381][image|1847379][image|1847380]
lls761 의
Dueling Banjo Penguins Christmas. Lets see what we can find. any chance you can get a close up of the connector. Looks a bit like a 3.5 mm connector on both ends
oldturkey03 의
I found the name of the product:
Animated Dueling Penguins, sold at Walgreens originally.
Music by Mike Aehle
https://www.youtube.com/watch?v=qe5n2WPw...
I still can’t find details on the cable, but it is likely a very simple cable that can be easily replicated or replaced. A lot of times, these things use 3.5mm or 2.5mm male to male mono cables to communicate. (These are the ones where there are 2 metallic section on the plug separated by a plastic ring. Stereo version will have 3 metallic sections with 2 plastic rings.
They also made other dueling banjo toys including snowmen, bears, etc. Maybe we can run-down the info from those variants as well.
Isaac 의
댓글 1개 더보기
