주요 콘텐츠로 건너뛰기
Device repair and information for the Vizio D-series 50" LED television with model number D50n-E1.
77 질문 전체 보기
Why can I hear my tv but I have no picture
My TV has no picture but it has the sound and the screen is completely black with a crack and little lines why can I not see the picture now but I can hear all the sounds
Update (09/15/2019)
this is the tv
Update (09/15/2019)
this is it'''
Update (09/15/2019)
this is it
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
I posted pictures hoe much would it be
댓글 달기
답변 2개
선택된 답변
The crack tell me that the LCD in it is gone
Did it get a fall??
Once the LCD goes in a TV in my view they are not worth repairing
Would cost more then the TV is worth
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
It didn’t fall it got tapped the picture was there then it went black but still had the sound
댓글 달기
Jasmine Brown just like @kingdasher is suspecting, this sounds like a broken LCD. Post some pictures of what it looks like with your question so we can verify. 기존 질문에 이미지 추가하기
If it is indeed a broken LCD then it'll be very difficult to find a replacement and even if you do it will most likely be more than a new TV.
Update (09/15/2019)
Ay, sorry Jasmine Brown. That is definitely a broken LCD. No repair possible. It would require a replacement. Now how far do you want to go with it? If you want to go all out and see if you can tackle it, let us know. First step would be to replace the back from your TV and check the label that is glued to the LCD panel. Let us know what that number is.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Jasmine Brown 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 5
전체 시간: 141
