주요 콘텐츠로 건너뛰기
Nintendo Switch Joy-Con 컨트롤러의 수리 안내서와 정보.
Why won’t my left joy con charge?
I had recently changed my switch shell and everything was working so far and then I connected my left joy con and it will work but it won’t charge, so the only way I can use it is on the switch itself. My right one works fine but my left won’t charge.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 8
댓글 1개
I was having an issue with the left joycon not charging and eventually the battery died due to this. I was going to buy a new battery and install it myself. But to make sure that was the problem my plan was to swap the bad battery with the good one in the right joycon. When I opened up the left joycon I noticed the battery cable had come unplugged so I just plugged it back in. It was a little tedious to do since everything is so tiny but once I got it plugged back in it worked fine, no issues.
Just thought I'd let everyone know in case the same happens to someone else
댓글 달기
답변 3개
선택된 해법
I know this question was asked a good many years ago, but I found it just now and decided to comment for the next viewers. I hardly use my joy cons, preferring to dock with a pro controller, I had left both joycons in the original grip to float around the house till I needed them again. Only to find that the right would register, but not charge. My first thought was the rail … and I bought a new rail. I took the left battery to try it in the right, and I found it wasn't an issue of both rails. I then took the right battery and placed it in the left controller … yeah, I need a new battery. Plus side of the new rail, it doesn't release as easily as my white box original rail did, I'll be keeping it. Btw, batteries are easy to change with a pair of pinpoint tweezers. You may want to connect the terminal before putting the battery in its place if the wires are not twisted for it's appropriate side already. Just make sure you don't try to connect it backwards, if it is not an easy fit, try the other side.
이 답변이 도움이 되었나요?
점수 4
댓글 달기
Either you don’t have the battery connected, or your battery is faulty! Try unplugging then replugging the battery connector on the joy-con and see if that works! It could also be the connector for charging the left joy-con, try unplugging then replugging the connector on the switch itself, as well as inspect the cable/wire for both battery on the joy-con and charging cable for switch!
이 답변이 도움이 되었나요?
점수 2
댓글 달기
I had the exact same problem (changed the shell, left and only left joy con didn’t charge but still worked while docked), and when I went to my local game shop they docked my left joy con to a different switch console. The battery indicator said it was fully charged, and when I docked my left joy con back on my console, the battery indicator was working, and it was fully charged. You can also try updating the joy con firmware under settings, which I did as soon as I got home, and haven’t had problems since.
Hopefully this helps anyone in the future with this problem.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
Rey 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 22
지난 7일: 164
지난 30일: 771
전체 시간: 62,073
