주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3530 질문 전체 보기
Flash, front and rear camera all not working
Hey guys, pretty new to this. Recently repaired the WiFi and Bluetooth antenna on my iPhone 5s. When I’ve put it back together, the front and back camera are both black and the flash won’t work at all.
any one got any ideas on this?
Thank you.
gary
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
The Front Camera and Flash will not work if the Rear Camera is defective/damaged/disconnected so focus your efforts on the rear camera. Start by verifying if it is properly connected. You can also check the condition of the connector (flex and board) as well as the general condition of the flex cable itself and the logic board. The flex is delicate and even the tiniest tear can cause issues. Likewise for the logic board as there are tiny components all around the connector and damaging or dislodging components can happen.
If everything looks okay, you could try to disconnect the FCAM & Flash and see if the Rear camera works by itself. If it doesn’t, then consider replacing the camera.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Gary Freeman 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 3
전체 시간: 34
