touch screen stopped working need to know how to fix it?
My touchscreen stopped working all of a sudden.The only way to use tablet is with the detachable keypad.
좋은 질문 입니까?
좋은 질문 입니까?
You really need to have it looked at as it may just be a loose connection or the display may need replacing.
Try booting into Safe Mode, which temporarily disables all 3rd party apps. On most Android devices, while powered on, press and hold Power until the Power Off menu appears. Press and hold the Power Off selection until the Safe Mode prompt appears. Tap OK.
If the problem disappears in Safe Mode, then something you installed is causing the problem. You may have to uninstall apps one by one until the problem disappears. If the problem persists in Safe Mode, then it's more likely to be a hardware or firmware problem.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 1
30일 전: 5
전체 시간: 444
