Where is the circuit breaker located? I need to reset it.
The circuit breaker on my HP CP1215 tripped and I don’t remember where it is to reset it.
좋은 질문 입니까?
좋은 질문 입니까?
Hi Danny
From my understanding, I doubt there is any known reset breaker.
Based on the parts I see, there are 110V power supply parts and also 230V power supply parts.
110V
https://www.priceblaze.com/rm1-4815.html
230V
https://www.aliexpress.com/item/32472137...
In summary, due to wrong voltage,
Primary side of the power supply components has been damaged, e.g. bridge rectifier / transistor etc, so thats why when you on, your ELCB trips..
the only way is to remove the board and perform repair or replacement.
so when using 220V ..... you need to use a step down voltage transformer for this ...
해당 답변은 도움이 되었습니까?
Danny Ballard I am not familiar with any resettable breaker on this model. Let us know what your printer does, or does not do, so we can try to help you with it.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 2
30일 전: 14
전체 시간: 378
댓글 2개
Hi Danny
What has happened?
Had you tried with another power outlet?
is the side power switch in ON position?
Augustine 의
@salmonjapan Yes I have tried several outlets. It is 110 voltage printer and was plugged into 220. It has done this before and I was able to reset it but I can't remember how I did it. I heard the circuit breaker trip when it was turned on.
Danny Ballard 의
