주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3530 질문 전체 보기
How do I measure output voltages at Tristar?
I am trying to figure out why I can get the voltage readouts from VCC Main and Batt VCC, but not other lines, even when VCC main is the supply for that IC. For example, Chestnut is supplied by VCC Main, but when I try to measure the 6v Boost at C329, I get no voltage?
What is going on here and how do I measure outputs, please give an example such as chestnut or tristar adn how you would go about measuring outputs.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
Have you got your screen connected when checking 6v Boost?
댓글 달기
답변 1개
선택된 답변
When measuring voltage rails, they are all done in the same manner. So if you are successfully reading VCC_MAIN and BATT_VCC for example, the same method will apply to reading PP6V0_LCM_BOOST. Now obviously, you have to insure you are probing the correct side of the capacitor (not the ground side).
Some rails don’t give the expected voltage under passive conditions, such as a logic board connected to battery only because the power IC is waiting for some kind of timing signal or feedback loop. A good example of this is the ANODE line, it will only read the same as VCC_MAIN unless it detects a screen, in which case it will boost the voltage.
Unfortunately, without seeing you in action, I can’t really say if you are doing something wrong. It may be that you are probing a dead circuit and that it is “normal” that you aren’t reading anything. Check on constant rails such as PP_CPU to see if you can measure some voltages.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
pts8091 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 5
전체 시간: 99
