주요 콘텐츠로 건너뛰기
Announced in August 2017년 8월에 발표된 Galaxy Note8을 회수된 Galaxy Note7의 후속 모델입니다. Note8은 대중이 구매할 수 있도록 2017년 9월에 공개되었습니다.
20 질문 전체 보기
I shattered my screen, and now a portion of it wont respond to touch.
I shattered the screen on my note 8 further, a day after ordering replacement glass for a relatively small fracture it already had. I have a little bit of experience fixing stuff like that and was planning to try to fix it on my own, however now the middle third of the screen is unresponsive to touch. Would replacing the glass fix this, or should i order a new AMOLED?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
if you can see everything on the screen perfectly fine and it’s just the glass that is shattered and unresponsive to touches replacing the glass would probably fix it but it might be much harder than replacing the whole assembly
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Hi @c0nman46
As long as you ordered a quality replacement screen, all of your issues should be resolved with a screen replacement. Damaged Samsung AMOLED screens tend to degrade worse and worse over time until they do not function at all.
I’m hoping that you ordered the screen pre-installed on a frame, otherwise this will be a VERY difficult repair.
Best of luck fixing this up!
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Con Coster 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 73
