주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
24" 화면; 내장 iSight 카메라, 마이크 및 스피커; 1920x1200 해상도. 2008년 10월 출시, 모델 번호 A1267로 식별.
Backlight issues here's how I fixed mine!
@John &Io Nut
I have an LED cinema display 24" from 2009, I have excatly the problem that the screen blanks out after a 1 sec flash of the image (probably LED driver signal turns down). I was about to try the bypass solution above for the 3.3V drive input, but then wanted to ask first if the same backlight strip probem problem could be on my LED Display as well, because I would not want to loose the dispay dimming possibility.
update:
So I did take the LG LCD panel apart in search for the notorius LED Strip, see pictures:
이미지
Taking the LCD apart:
The LCD frame,
이미지
The Backlight panel,
이미지
The plastic frame,
이미지
이미지
The glass of the panel,
이미지
The back plate,
이미지
Finally getting down to the LED Strip
이미지
So I did resolder the LED connector (just added some solder to it and re-heated the 5 pins again thoroughly), but my problem still persists, the LED stripe only flashes quick at connection display port connection time. I am considering of doing some logic measurements tonight with my oscilloscope for the LED driver, but the willi fix for bypassing the 3.3V is starting to sound tempting (still trying to find out the real reason for this failure, and I have to admit that the LED stripe fault sounds more plausible to me due to the drive signal LED shutdown after one second flash.
Update (23.02.2017)
@io nut
I made some advancements with the display but the reason for the fault is still unclear.
All of a sudden the LEDs decided to turn on again.
이미지
I am convinced that it has something to do with the horizontal positioning of my setup. While lit I quickly checked the LEDs and realised that Led nr. 27,30,40 and 60 are out. Next day when I started the display the background lighting did not lit again.
I figured it might have something to do with grounding and tried out connecting the displayport without the USB cable. No effect the LEDs turn on with or without the other USB connector and/or the Powerconnector. I realised that the LED cinema display brightness can not be adjusted without the USB cable connected to the my macbook pro.
이미지
Update (26.02.2017)
LED illumination pattern 2/3 Leds.
이미지
LED illumination pattern every third LED
이미지
Update (27.02.2017)
So after all the MODs my display is running again. Eventually I ended up only changing 9 capacitors (3 pcs of each of the black ones in the pic, the orange ones I still have originals) on the powersupply,
이미지
and resoldering the LED stripe connector,
이미지
in addition I assembled and reassembled the display several times (loose connectors).
So Im still not convinced about the source of the fault and Im now testing the display for a week, lets see if it actually stays on.
Update (05.03.2017)
My Apple LED Cinema Display 24" is still up and running.
Update (03/22/2017)
Unfortunately I have to report that my LED cinema display died again after one month of fluent usage. So Im back to square zero. :!
Update (15.05.2017)
I decided to try out if my display runs and it seems to run again :). So lets see for how long, but I am suspecting some sort of capacitor voltages that are incorrect due to capacitor ageing.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 9
댓글 10개
Robert, excellent pictures !
If you are absolutely sure you have resoldered properly the connector, and the symptoms are the same that means the problem must originate somewhere else. Your symptoms are different from the ones I have experienced, but it definitely sounds like a detected fault triggers the backlight to shut down. (is it just the backlight that shuts off?- do you have an image on lcd if you shine a light on the lcd?)
Does the whole strip light up during that 1 second? Noticed any LED stay unlit?
Is the octopus cable ok? Tried different one? (Yours could short out, like mine did initially).
Cover all your bases and now that you got so far, do not rush ! Ultimately, try the bypass mod, but in a non-destructive way, so you can undo it if necessary.
Thanks for the rapid answer. I basically ruled out the octopus cable malfunctioning because I actually managed to start the monitor, but only the first time. So I got a nice and bright (with backlight) picture, but as soon as I restart the monitor the backlight just blinks and then shuts down again, probably some capacitor malfunctioning in the Logic board.
I did not realise any dark LEDs during the very brief flash of the LEDs (cant say for sure though). So I basically now have the monitor open and plain LEDs connected to the Logic board.
I ll try to get another octopus cable somewhere to try out, I havent tried that yet. Though I think the cable is not the fault since I have succesfully turned on the monitor 3 times (always after a long break or disassembly to let the charges out).
How would you do the bypass in a non destructive way? I mean once I have the resistors out it could be quite a challenge to get them back into their places.
Non destructive way, meaning do not cut traces or destroy the 0 ohm resistors when you take them out. Use two fine tip irons ( or one tweezer tip preferably) and heat up both ends of the resistor at the same time and lift it off the board. Save it on a sticky tape in case you need to put it back on. Solder it back the same way, but use some flux on the pads. It is easy.
I am assuming, you have done the firmware update for both the monitor and the macbook...?!
I am actually running an old macbook pro mid2010 15" OSX 10.9.5 so it still has a display port instead of thunderbolt port, the firmware update I found would not install saying "your computer does not need this update " propably due to the fact that I have a display port instead of the never thunderbolt port.
I also tried the Macbook pro of my girlfriend, mid2010 13" running a OSX 10.11.6 El Capitan.
댓글 5개 더보기
댓글 달기
답변 5개
선택된 해법
Update (2018/09) My display is still up and running after changing the Capacitors, but I reckon this is only coinsidense. I would advice you to have a look at James Stuart comment/explanation below. I think it makes the most sense and explains the cause of the problem well!
James Stuart at: https://de.ifixit.com/Antworten/Ansehen/...
I don't mean to offend anyone but you all seem to have missed the blatantly obvious and that is the LED backlight array.
LEDs age, and as such the amount of light that is emitted reduces. The LEDS in the LM240WU6 panel are made by Lumileds which is a subsidiary of Philips who in turn produced the panel under license from LG. The LEDs used are LXML-PWN1-0120 which should be operated at a forward voltage of between 3.0V & 3.6V @ 350mA and have a stated 39000 hours of life.
LEDs operate in constant current mode that is the current through the device is adjusted by altering the voltage across it. In low current LED applications this done with a simple resister. In high powered applications this is done with a controller chip such as the HV9982. Most high powered applications work as a closed loop system, that is they monitor the current flowing in the LED string and adjust the voltage across the string accordingly. The circuit Apple adopted does just that, it monitors the voltage developed across a low ohm resister in the bottom of the LED string and adjust the PWM signal to the HV9982 that will adjust the voltage to the LEDs. The suggested fix above of applying 3.3V to the PWM input will remove this feedback and will apply maximum voltage across the LEDs and is likely to result in damage to the LEDs and driver circuit.
What most people are experiencing is the backlight driver circuit shutting down due to it reaching an overvoltage point as it tries to pump more current through the aged LEDs.
(picture in the original post)
The above plot shows the current through each LED with a forward voltage of 3.3V. As you can see there is a lot of variation (LED 1 shows as 0mA), none of them get near the 350mA that they should.
Conclusion, the only long term way to fix this problem is to replace the LED string as a whole or at least the weaker LEDs. The individual LEDs are available from DigiKey but they will prove difficult to replace as they are surface mount and are tied to a heat sink back plate. An alternative is to retrofit a low voltage backlight replacement string, they are available on eBay for as low as £4. These will require a 12V supply and will need to be turned on and off manually.
Update (06/14/2020)
I got some more equipment and returned to fix my 24” cinema display. So in the meanwhile the display was working like every second day by chance. In the meantime I found a donor cinema display with the same defect. Backlight shutdown after a flicker of light.
So I decided to open my display again and took out the led strip totally to test it. I only have a 30V regulated power source so I could test the whole led array (60Volts needed). But I tested the leds individually and they seemed to at least light all one by one with significant differences in luminousity. Now I wonder how to find out which ones should I replace without desoldering all of them. I desoldered 4 of them with my new hot air station, but it is quite tedious to get one out.
Update (06/14/2020)
이미지
이미지
이미지
이미지
이미지
Update (24.07.2020)
이미지
I found the Lumileds to order, but investing like 130CHF (approx. 130USD) is a bit too much for the moment, for this project. Besides I tried unsoldering with hot air station that I ordered a few of those LEDs and it is indeed possible but quite tedious, so perphaps not worth the time and money.
This looks like the original one:
https://www.alibaba.com/product-detail/-...
이미지
From the original LumiLed Datasheet, the SMD LED component footprint:
이미지
이 답변이 도움이 되었나요?
점수 5
댓글 17개:
There is mention of a comment from John Stuart but I don’t see it anywhere?
This looks more like the correct ones in Alibaba:
I have now changed the LED bar from a donor Cinema display and it works like a charm since a week already. It always starts immedeately and the display is dimmbar normally.
LEDs age, and as such the amount of light that is emitted reduces. The LED’s in the LM240WU6 panel are made by LumiLEDs which is a subsidiary of Philips who in turn produced the panel under license from LG. The LEDs used are LXML-PWN1-0120 which should be operated at a forward voltage of between 3.0V & 3.6V @ 350mA and have a stated 39000 hours of life.
The LED strip has a sticker on it:
* P1803001D
* P66L01746
I have the same issue and i suppose the problem is the led strip, can you please help me what led strip to order? Can you give me link? My model is Apple A1267, thank you
댓글 12개 더보기
댓글 달기
Hello,
Great Infos here. Few weeks ago I bought a Cinema Display 24” for a cheap price because it didn’t work. I followed the Apple Technician Guide : the LCD was working but not the LEDs. No backlight. Voltage at the check points was Ok on the mother card. I checked the LEDs inside the display and they seemed old to me, one was even broken. As I couldn’t find any replacement part, I finally bought another display for about 150€, almost brand new one.
I replaced it today and it is the same story, no backlight ; the LCD is still working though, like the old one. I was sure the LEDs were down but obviously, the problem is elsewhere. Probably the logic board I think (?). Or could it be something else, power supply, cable ??
Just to say beware of the Apple Technician Guide, it is bullshit. I just wasted my money because of it. Now I have to buy a logic board to try it out and it is not really cheap…
이 답변이 도움이 되었나요?
점수 1
댓글 7개:
So, I finally ordered a logic board on Aliexpress and the display is now working… It was actually the real problem! Once more, the Apple Technician Guide is real bullshit. Probably the voltage check points are useful for the LCD panel but not for the Led strip supply.
Unfortunately, the USB ports are now not working and I can’t adjust the luminosity. I guess this is also because of the USB issue. The logic board was “90% new” as described by the seller, but obviously it is was an old one which doesn’t work properly. Dispute open….
I also ordered LED strips for Thunderbolt Display 27”, the most expensive ones as I though it was a brand new item :
https://fr.aliexpress.com/item/328453350...
But beware! It is another “100% new” item in the description which turns out to be old Led strips. Some Leds were actually broken and of course the strips were used, not new! (the seller has corrected the description after my dispute)
It seems that it is almost impossible to find new parts for these Apple stuff, though the display 24” I bought for 150€ on Aliexpress was probably almost new.
Did you test your original LCD with the new logic board to see if it was functional?
I'm looking for a panel for mine, If you are willing to sell...
Many have identified that the problem exists in the LED strips which now are quite old and EOL. The problem for most of us is sourcing the LED strip for the 24 inch. After months, I just gave up. The 27 inch strips are apparently available on AliExpress. If anyone has found a source for the 24 inch, please post. Thanks
@teejay2000 I managed to source a LED light strip replacement from Ali. It was just £7.
It arrived very quickly from China and was very well packed.
In their listing on Ali, they state you should adjust the resistors in the driver circuit, but my finding was it worked from the off (maybe they were futureproofing for when the new LEDs will eventually go)
The link to the replacement is https://vi.aliexpress.com/item/100500618...
I can confirm it works. I did notice, however, that when you crank up the brightness to the very top, it seems to have a flicker.
댓글 2개 더보기
댓글 달기
You can check the LED strip with 54 to 57 volt attached to the 6 pin connector. But be aware of the crazy order of + (anode) and - (cathode) for the 3 LED strings.
It is: string1-, string2+, string1+, string2-, string3+, and string3-.
이미지
Each string draws around 10 mA at 54 V, 20 mA at 55V and 30 mA at 56 V.
My DIY connector for testing all 3 of them:
이미지
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
For the LG 27" panels (09-11 iMac 27 and 27" Cinema/Thunderbolt Displays) I have fixed many just by resoldering (wick off old solder, reflow with leaded solder) the connector's solder points on the LED light bar. Its the weakest point and lead-free solder weakened by thermal cycling. I even had one that just fell off when I disassembled it. Anyway, reflow fix black out problems everytime.
I don't know if 24" panels suffer similar problem. 27" probably has the most LEDs on the LED bar.
댓글 달기
Just ordered a few of these LED strips, and when they arrive and I build up some enthusiasm to fix a couple of the dead cinema displays I have stored... I will replace. Or try to. Good luck to all trying this as well. I can't believe LED strips for the A1267 are available.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Thanks for the original post. It helped me, and especially the final outcome and information
The link to the replacement is https://www.aliexpress.com/item/10050061...
WARNING:
The plastic strip that runs parallel with the old LEDs gets very brittle and can crumble easily. I had to glue mine back in at the far tip.
My big lesson from this was BE VERY CAREFUL when putting the LCD back into its resting place! One of the 4 protruding LED driver circuits flipped right back. Result: 1 quarter screen is messed up!
Be careful.
Luckily I got it for free
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Robert Nawfal 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 28
지난 30일: 143
전체 시간: 16,169
