주요 콘텐츠로 건너뛰기
Repair and disassembly guides for GE Microwave ovens.
349 질문 전체 보기
GE Microwave #JES2251 not working. How to get door open?
All of a sudden, our GE Microwave Model #JES2251 cannot be opened because the door button is totally flimsy and not working. How do we get the door open if the button doesn’t work?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
drdorazio85  you will have to remove the outside cover by removing the screws (41) from it. Then you can see where the door lock latches into. Use a pair of pliers etc. to open it. Make sure that your MW is unplugged and don’t touch anything on the inside of it. Yet.
해당 답변은 도움이 되었습니까?
점수 2
댓글 7개:
When you say remove the outside cover, do you mean the trim around the microwave door? I've been trying to remove that, but I can't see any screws holding it in place.
drdorazio85 the metal cover which should have the screws in the back. Kind of like disassembling the MW
There doesn't seem to be enough room to get to the screws underneath the trim
panel at the top.
I was hoping taking the button off (the spring is now reglued to the back of the button) would expose something that I could push to get the microwave door open. Then I could get to the screws. Any tricks to opening the door when the button isn't working?
Hi, oldturkey03, I had to break the plastic door latch to get the door open. Now I have the trim panel off and am working to get to the button mechanism so I can see what is broken. Hopefully, I can order parts and get this fixed! Thanks for your help!
댓글 2개 더보기
댓글 달기
귀하의 답변을 추가하세요
drdorazio85 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 5
전체 시간: 209
