주요 콘텐츠로 건너뛰기
Samsung에서 제작한 Android 스마트폰, 2017년 1월 출시.
77 질문 전체 보기
Why is my phone not charging and giving off a burning smell?
I have a Samsing Galaxy A5 (2017). One day it stopped charging and when plugged in, a burning smell is released from the charging port. The other end of the cable also gives off a burning smell. Any solutions, or advice on what I should replace? Also, what is the best adhesive/tape I can use to install the acrylic back after removing it? I’m looking for some adhesive that I can find somewere like bestbuy or walmart.
Thanks.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 3개
If my charging port smells like burning how do you stop it from burning
My galaxy a01 charger port smells like it's burning and this greasy stuff is on the back of my phone what is it? and what should I do?
How do I get it to charge again?
댓글 달기
답변 3개
가장 유용한 답변
@thestrangeslav something on your charging circuitry went array. You want to go ahead and stop trying to charge it etc. Then you want to go ahead and disassemble your device. Start this by using these guides Samsung Galaxy A5 (2017) and/or this video Then check your circuit boards for obviously damaged components etc. Post some good pictures of your boards with your QUESTION. That way we can see what you see. 기존 질문에 이미지 추가하기
After that follow the troubleshooting steps as suggested on here
The connector IFC6001 is available at places like this
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
if you smell a burning smell at both ends of the cable try a different USB Adapter and see what it does. on the samsung galaxy a5 it does not use adhesive, the screen just clips in.
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
Actually this model the screen is held by very strong adhesive. There is also adhesive for the back glass.
It sounds like the USB-C charging socket on the phone needs to be replaced. This is quite difficult to do as it is soldered onto the logic board. This I would leave it to a local reputable phone repair shop to get it fixed.
First thing to do is try another wall charger and cable if you still smell the same electrical burning smell it means the problem is with the charger port instead.
go look up a disassembly on a samsung galaxy a5
댓글 달기
if you smell burning it was caused by electricity and is melting/ burning something change USB adaptor see if that works if not change the charging board in the phone.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Ayden Aldrich so what's the fix? How can you help the OP repairing his device? How does your answer help the OP?
댓글 달기
귀하의 답변을 추가하세요
David 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 15
7일 전: 56
30일 전: 271
전체 시간: 31,735
