주요 콘텐츠로 건너뛰기
Scientific calculator by Casio. Widely used by students world-wide due to its great quality for the low price.
37 질문 전체 보기
How do I fix my calculator that only runs on solar power?
My Casio fx-991ES PLUS was dropped and now the display does not light up unless it is under a light source. It has a mini solar panel which I assume it using for power and it has new batteries in it but they do not seem to work. Is there something I can do to fix it?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 5
댓글 1개
I replaced mt calculators
댓글 달기
답변 2개
선택된 답변
@madrthanevr could simply be an issue of torn wires/ connectors or something more sinister like an issue with the power management IC on your PCB. We’d need to see what is going on inside your calculator 기존 질문에 이미지 추가하기
해당 답변은 도움이 되었습니까?
점수 4
댓글 3개:
Thanks @oldturkey03 there was just a disconnected wire. Probably should have checked beforehand. Much appreciated!
My casio MJ-12D is not working after putting in sunlight.....what should i do for this??
@madrthanevr how did you check the wiring? I have a similar problem
댓글 달기
Casio can replace the broken screen, they will give you a price before they do the repair, by the time you add shipping to them and shipping back to you, you will be better off just buying a new calculator and keeping this one for spare parts for the next person who wants to buy a motherboard.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
MadRthanevr 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 11
7일 전: 79
30일 전: 333
전체 시간: 22,796
