Input needed for Mac shutdown code 128
Hi,
My Mac has shut down a couple of times with shutdown code 128. I checked the following ifixit post though I am not sure if its a memory related issue since I never see code 112 and also don’t really see excessive memory activity in the Activity Monitor.
How to determine Mac shutdown causes
I am considering cleaning up inside the macbook pro once I confirm if its actually dusty and also do a hardware test if needed, as suggested in this thread:
https://apple.stackexchange.com/question...
Any suggestions?
-Sharath
좋은 질문 입니까?
댓글 2개
Hi,
I did run the Mac diagnostic test which gives the following message.
”The battery will need to be replaced soon.
It is functioning normally, but holds less charge than it did when it was new.
Reference Code: PPT002”
Apple’s online support page basically gives the same advice:
https://support.apple.com/en-us/HT203747
I called up Apple Customer care and they offered to get the battery replaced with an estimate of $129 + taxes.
Any thoughts/comments?
Thanks,
Sharath
Sharath Raju 의
Did anyone else face a similar issue and was it solved by simply replacing the battery?
-Sharath
Sharath Raju 의
