주요 콘텐츠로 건너뛰기
The Alienware M14x is a laptop designed for optimum gaming experience and content.
2 질문 전체 보기
Laptop GPU reflowing- help needed
Hi I want to reflow the gpu on my only laptop by myself, I can't trust repair center or can't effort a new laptop .
I kind of bent the main board so this happened.
Question : I want to reflow gpu using heat gun and laser thermometer for measurement , what's the best melting temperature for it? I saw people go up to 260 but I usually solder joints melt at 200-210 Celsius , so I'm wondering if lower temperature will reduced the risk of burning the gpu completely…
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
@javid_zare_s a reflow is not going to fix a bend motherboard. If the solder connections or pads have come loose they will not go through a reflow. Remember that a good reflow is more than just blasting an area with a hot air gun. Anyhow, I suggest you follow the profile as outlined on here
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Javidzed 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 3
전체 시간: 428
