주요 콘텐츠로 건너뛰기
모델 A1297 Unibody: 2009 상반기, 2009 중반기, 2010 중반기, 2011 상반기 & 2011 하반기
544 질문 전체 보기
MacBook Pro crashing immediately when booting from El Capitan USB
I have a 17” MacBook Pro from Mid 2009.
The previous owner removed the hard drive, so all I really have to do is reinstall OS X El Capitan.
When I boot up, hold option, and select the USB flash drive, the Apple logo appears. A progress bar appears shortly after before the screen goes black and the computer turns off.
My flash drive is detected in my Mac Mini, and all of the contents of the installer are there.
I opened the computer, and put in a new hard drive. All the components are there and there is no water damage or graphics anomalies.
Since these “not booting” issues are so vague, it’s hard for me to troubleshoot. Any help is much appreciated.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 3개
What is the drive you are trying to use? Make and Model.
@danj I'm just using a standard SATA 500 GB 5400 RPM hitachi drive. I tried 2 different hard drives, one Toshiba( mq01abd050) and one Hitachi (Hitachi Travelstar Z5K500). My model is the Mid 2009 2.8 GHz model.
댓글 달기
답변 3개
선택된 답변
I reset the SMC by holding Shift+Control+Option and Power and it’s working now. Thanks to all those who helped.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
가장 유용한 답변
Boot from the USB drive on your MacMini to confirm it works and we can go from there.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Flash drive works.
댓글 달기
Both the Toshiba MQ01ABD050 and Hitachi Travelstar Z5K500 are SATA II (3.0 Gb/s) drives. Either should work here once they are formatted and the OS is properly installed.
The rub you are facing is the limits of the USB port. If I remember correctly this series won’t boot from it.
So you’ll need to prep the drive from a second system that can be booted from the USB drive.
Here’s the best guide on setting up the needed USB OS installer drive: How to make a bootable OS X 10.11 El Capitan installer drive
Using your Mac Mini you’ll need to get a SATA to USB adapter cable to connect the drive StarTech 2.5" SATA to USB adapter cable. Then using the other USB port plug in your OS installer drive. Now reboot your system but you want to hold the Option key of your keyboard to gain access to the startup manager. Then select the USB OS installer drive. Make sure you reformat the external drive GUID with a Journaled file system using Disk Utility and when the installer asked you which drive make sure you select the correct drive.
Once done, transfer the drive to your 17” MacBook Pro it should work this time. Go into system preferences altering the Startup Disk to your new drive.
Reference: Mac startup key combinations
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Eric Zhang 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 10
전체 시간: 1,647
