주요 콘텐츠로 건너뛰기
Apple의 2016년 개정판 노트북은 전문 사용자를 대상으로 제작되었습니다. 15 인치, 2880 x 1800 Retina 화면, 쿼드-코어 Intel Core i7, 256 GB / 512 GB / 1 TB / 2 TB 저장 공간 옵션, 16 GB RAM, 그리고 Touch Bar가 장착 된 키보드가 특징입니다. 2016년 11월 출시되었습니다. 모델 A1707.
253 질문 전체 보기
One of my USB C ports is not working, what’s the repair process?
Hi! So recently my MacBook randomly stopped working properly. One USB port is no longer working. No power or device works on that port. Every other port works perfectly fine. What’s the repair process to fix that si glue port?
Thank you!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 4개
Is the mate port working?
Does it seem to be loose?
Hi, sorry I'm not sure what is the mate port? It doesn't seem to be loose.
@Ayushmaan Ganotra - The mate is the one beside it. Each side has two ports. Lets call them Left and Right and A & B
Left Side: Port A - Port B
Right Side: Port A - Port B
Which one is giving you trouble?
Hi yeah the mate port does work. It's on the right side. When looking at the laptop it's the one closer to the trackpad.
댓글 달기
답변 2개
가장 유용한 답변
First step would be testing power and data lines of the Usb port..a multimeter would do for first ones and an oscilloscope would be needed for data lines, providing you have a good board to compare results with. Other than that you’d need a skilled repairer into component level repairs.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
A simpler way would be a simple USB-C power meter like this one: Satechi USB-C Power Meter
댓글 달기
OK thats a good sign! So the port connector is likely the problem Vs the driver chip behind it on the logic board its self (both ports would have been effected)
Here’s the needed part: MacBook Pro Retina (A1706 & A1707 Late 2016-2017) USB-C Board
You’ll need to first follow this guide to get the bottom cover off: MacBook Pro 15" Touch Bar Late 2016 Lower Case Replacement Then you’ll need to take the logic board out to gain access to the two screws holding the connector core. While it looks daunting its not too bad! Just carefully disconnect the ribbon cables which are held by the metal covers and the mount screws. Use the MacBook Pro 15" Touch Bar Teardown to help you see when everything is. Once the board is out you can gain access to the screws.
MacBook Pro Retina (A1706 & A1707 Late 2016-2017) USB-C Board 이미지
상품
$19.99
MacBook Pro 15" Touch Bar Late 2016 이미지
안내서
난이도:
운영
MacBook Pro 15" Touch Bar Late 2016 Lower Case 이미지
안내서
난이도:
운영
5 - 10 minutes
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Hi. This is super helpful! I'll give you an update on the situation once I get the parts.
댓글 달기
귀하의 답변을 추가하세요
Ayushmaan Ganotra 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 5
전체 시간: 1,794
