주요 콘텐츠로 건너뛰기
모델 번호 A1238 / 80, 120, 또는160GB 하드 드라이브 / 검정색 또는 은색 금속 외형
904 질문 전체 보기
Battery is replaced but still have some questions?
I just painstakingly replaced my battery in my iPod classic 160gb. It works now but seems to have some charging issues, not sure what that’s related to. It charges but when I disconnect after 4 hours charging, still shows about 35% charged, no more. Is there something I did wrong in the replacement or in restarting it? HELP!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
@eldestroyo nope does not sound like anything you did. It is possible that this is a bad battery but it is also possible that you are running into issues with the battery. connector. Keep in mind that this connector has a tendency of easily breaking of the logic board. You may want to carefully inspect it. I use an L-shaped paperclip whenever I pull up on the locking mechanism of the connector. I find that by using any other tool I would always push the connector sideways and thus running greater chance of breaking it.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Ryan 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 3
전체 시간: 23
