주요 콘텐츠로 건너뛰기
Android tablet released in January 2015. The Dell Venue 8 7840 has an 8.40 inch display with a resolution of 2560 pixels by 1600 pixels.
6 질문 전체 보기
Screen Tearing and Low Battery
NOTE: Not a Dell Venue 8 7840
Hello, Recently bought a Used Dell Venue 5050 (Not Pro) it booted up fine then Last Night i started getting Screen Tearing wondering if its the battery or the O.S.
Also its running android Lolipop
And Battery was only holding 25% Charge as of Last Night
Thanks in Advance, Andrew
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
@born7 screen tearing should not be a battery issue. That is usually caused by the OS and/or memory. Try to charge your battery completely and then reset your software.
해당 답변은 도움이 되었습니까?
점수 1
댓글 3개:
Then what would you recommend how do i run tests for bad memory or O.S. on Android or do i have to connect it a computer and factory reset it
Also how do you go about factory resetting this model of Dell Venue (5050) (Non Pro)
@born7 for a reset, this should work for your tablet. https://www.hardreset.info/devices/dell/...
now this "Battery was only holding 25% Charge" could definitely be a battery issue.
댓글 달기
귀하의 답변을 추가하세요
Baz 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 4
전체 시간: 62
