주요 콘텐츠로 건너뛰기
The Kenmore 90 Series is a washing machine manufactured by Kenmore.
266 질문 전체 보기
Will not advance past wash cycle
Model 110.92593220
Completes wash cycle but stops before rinse cycle with tub full of water.
Will work if I manually advance the timer.
I have replaced -
timer 2x
pump
control board
water level switch
transmission and clutch
I have checked the continuity of the lid switch.
I have almost replaced everything and it’s still doing it!
(@jayeff - I replied to your questions on my earlier post but it was removed as spam - I have addressed your questions in this post)
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
Unfortunately it’s not the lid switch
I did replace it and also tested the new one.
It spins when the timer is manually advanced.
Hi @david777 ,
Don't know your washer but have you tried both hot and cold wash cycles and all wash cycle modes to check if the problem occurs?
Can't find a wiring diagram but you may have to prove continuity in the wires from the timer, especially from the timer contact that is used when it goes to start agitating again after filling at the start of the rinse cycle.
I assume that this is what you meant when you said "...stops before rinse cycle with tub full of water.", i.e. water drains at end of wash cycle, tub refills a start of rinse cycle .
Or did you mean stops at end of wash cycle and doesn't drain and advance to refill for rinse cycle?
댓글 달기
답변 2개
선택된 답변
The water pressure tube that connects at the bottom side of the tub could be clogged. You can remove it from the pressure switch and blow through it but sometimes best to remove and clean it.
On this washer, the permanent press cycle has a “cool down”. I’ve had dozens of service calls that the complaint was, “it won’t advance”. But it was just in the cool down part of the cycle that can take awhile. The purpose is to cool the clothes before they go into a spin. The washer will drain a little water and fill with cold water and pause. The drain some and fill with cold and pause. You can check the schematic with the cycle to determine if your in the cool down.
Youve already replaced the timer and water level switch, those would have been the first to test. Did you test the timer and water pressure switch with a multimeter? If so, were they bad?
I can’t think of anything else that would cause it to stop other than what I’ve posted. I’d like to hear the outcome.
해당 답변은 도움이 되었습니까?
점수 2
댓글 8개:
David, does it happen on every cycle?
David, sorry for the questions, but to help I need to know how long have you let it sit in that spot? Also, did you replace the timer or just the timer motor? Did you check the resistance of the timer motor, and the contacts on the water level switch? The place where it’s stopping is where it goes into the drain and spin correct? After you check the water pressure hose and the cool down would you mind letting us know what you found, please? Thanks
@ladytech
@mayer
When I replaced the water level switch, I checked the pressure tube - no clogs, debris of any kind. In fact, I took it out and looked at the entire length - nothing.
Good suggestion on the permanent press "cool down" feature. I am aware of that feature (owned washer 25 years now), but that's not it. It will stay stuck there forever until the timer is manually advanced. I've waited hours, overnight and actually forgotten clothes for days in there only to discover the washer stuck with a tub full of water and clothes.
I did not test the timer before replacing (2x). I did test the water pressure switch using someone's online suggestion about the connectivity. Turns out I was doing it wrong and both old and new water pressure switches are good.
@ladytech
@mayer
It happens every single cycle. It stops right after the wash cycle with the tub full of water OR the washer will drain after the wash cycle and it will just keep pouring water in and it never fills - forever or until the timer is manually advanced.
I replaced the timer (part #3946474), not just the timer motor.
Your help is appreciated. I've owned this machine 25 years and I've now spent so much time trying to fix it that it's become personal - if I have to replace every wire and screw, I'm prepared to do that.
Hi @david777 ,
You didn't happen to notice if there is a wiring diagram located inside the washer by any chance?
Scroll down the link to view possible location in a washer.
댓글 3개 더보기
댓글 달기
I know you tested it but it the most common cause and cheapest to replace
Lid Switch Assembly
The lid switch assembly prevents the washer from spinning when the lid is open. If the lid switch assembly fails, the washer will not spin. To determine if the lid switch assembly is defective, use a multimeter to test the lid switch for continuity. If the lid switch does not have continuity, replace it.
https://www.repairclinic.com/PartDetail/...
Other Causes Video
https://www.repairclinic.com/RepairHelp/...
해당 답변은 도움이 되었습니까?
점수 1
댓글 8개:
@mayer
Please see my comment on lid switch assembly.
Appreciate your input.
@david777 watch the second link I gave
@mayer
Second link is to a lid switch assembly part, not a video
Sorry 'bout that, it's fixed now
@mayer
I reviewed the Common Solutions in the link -
1. Lid Switch Assembly
I have replaced the lid switch assembly and tested the continuity of the new one. In addition, the tub spins when the timer is manually advanced.
2. Motor Coupling
I examined the motor coupling when replacing the transmission, there were no issues. Also, the tub spins, just requires the timer to be manually moved from the wash cycle to the rinse cycle.
3. Clutch
I replaced the clutch when I replaced the transmission - still stops after wash cycle, before rinse cycle, with a tub full of water.
4. Clutch Band Kit
I replaced the clutch, there are no issues with the band and lining.
5. Bearing
The tub spins smoothly and without any unusual noises when it is spinning.
6. Drive Motor
The motor works fine - the tub will spin when the timer is manually advanced.
7. Basket Drive
The tub spins ok.
8. Transmission
I have replaced the transmission.'
댓글 3개 더보기
댓글 달기
귀하의 답변을 추가하세요
David 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 14
30일 전: 64
전체 시간: 2,713
