주요 콘텐츠로 건너뛰기
Apple의 MacBook Air 13" 2015년 5월 업데이트에는 5 세대 Intel Core i5 및 i7 프로세서가 성능과 배터리 수명을 약간 향상시켰습니다.
623 질문 전체 보기
MacBook Air only switching on with i/o flex cable disconnected
Hi guys
We have a MacBook which wasn’t turning on at all. The battery was charging. I delved inside, and found that by disconnecting the i/o flex cable the MacBook will turn on and operate as normal as long as there is charge in the battery. Plugging in the magsafe will then preserve the battery power but not charge it.
I’ve even managed to connect a flash drive to the USB port on the opposite side of the Mac, and have transferred files and done a time machine back up, and I’ve subsequently updated to Catalina. All I know is that I’m going to have to plug the flex cable back in to get it charged and then unplug it to switch it on.
Is there a way of testing the flex cable for any issues? I’m making the assumption that it’s either that or the i/o board that is at fault and not the logic board, but if anyone knows any differently I’d love to know!
Thanks
Christine
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Well it’s safe to say you’ve run the problem down to either the MacBook Air 13" (Mid 2013-2017) I/O Board and/or the MacBook Air 13" (Mid 2013-2017) I/O Board Cable
I personally would replace both following this guide MacBook Air 13" Early 2015 I/O Board Replacement
MacBook Air 13" (Mid 2013-2017) I/O Board Cable 이미지
상품
$14.99
MacBook Air 13" (Mid 2013-2017) I/O Board 이미지
상품
$79.99
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Thanks Dan I really appreciate your answer, and I am glad that you are verifying what I thought! I just need the parts and another screwdriver by the looks of it.
Cheers!
Christine
댓글 달기
귀하의 답변을 추가하세요
Christine M 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 554
