주요 콘텐츠로 건너뛰기
Repair and support for Slinky Toys. A coiled spring made of metal and/or plastic.
How to untangle a slinky as fast as it got tangled
I know you can work the tangle to the end (normally). Mine is welded closed at the end, so that’s just moving the problem to a new part of the slinky… But also, it made me ask the question I’ve always wondered: What is the trick to UNDO the original tangle. After all, if it’s that quick to tangle, it must be undo-able in 1 slick little move…
Any ideas
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 달기
답변 4개
가장 유용한 답변
I've not met a person so majestic to rapidly undo the knot of a slinky. But I can tell you that my method of undoing slinkys are relatively easier.
I would suggest stretching it out carefully to see where the knot is in the first place.
Then if you want, you can slide your thumb slowly through the coil, aligning everything in place slowly working your way down to the knot.
And then once you make it to the knot, flip it or untangle it slowly as you work your way down, carefully pulling the overlays apart.
이 답변이 도움이 되었나요?
점수 3
댓글 달기
Mike De Butts depends on how it is tangled. Most common method is outlined on here
이 답변이 도움이 되었나요?
점수 1
댓글 달기
i love your name but get it ok here its goes. use a ruler
Update (12/01/2020)
22222222222222222222
이 답변이 도움이 되었나요?
점수 1
댓글 달기
So basically what I did is I Kept rotating the coil different ways and eventually it came undone…Took around 10 mins depending on how much it is tangled✨
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Mike De Butts 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 26
지난 30일: 95
전체 시간: 18,576
