Why is it impossible to shift gears when my 1995 Ranger is hot?
I can drive my 1995 Ford Ranger for 30 minutes , and then it becomes impossible to shift gears until it cools for 90 minutes. What is wrong with my truck ?
Update (11/08/2019)
The 1995 Ford Ranger with a 2.3 liter engine has a 5 speed manual transmission.
좋은 질문입니까?
Auto or manual?
sm_vulkus 의
Hi @dtennisman ,
Have you checked the level of the transmission oil in the gearbox?
Do this on level ground.
jayeff 의
Did you rebuild or buy it
Noah 의
I will check the transmission fluid level, that seems like an important thing to do. I did not rebuild the transmission, it is original equipment with probably 200,000 (the odometer died 12 years ago), or more miles on it.
otrecords 의
Noah, thanks for the suggestion, but I definitely don’t grind my gears.
otrecords 의
댓글 1개 더보기
