주요 콘텐츠로 건너뛰기
The Craig CMP801 is a windows tablet powered by a 1.83GHz Atom Z3735G Quad-Core CPU, has a 16GB storage and includes the following components: Bluetooth 4.0 version, HDM1 accessibility, SD slot, and 1GB RAM.
It wont turn on. It doesn't seem to be charging.
It won't turn on. It doesn't seem to be charging.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
JCorley Gray  start by checking your charger, your charging cable. Then check your connector and see if there is any lint etc occluding it and if the cable fits snug or if it is loose. If all of that checks out you will have to tear your tablet down and replace the battery. While you have it open you also want to check the charging port connector (solder joints etc.) Craig CMP801 Battery Replacement
이 답변이 도움이 되었나요?
점수 3
댓글 달기
답변을 추가하세요
JCorley Gray 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 7
전체 시간: 332
