주요 콘텐츠로 건너뛰기
MacBook Pro 13" Retina Display, 모델 A1502의 2015년 3월 업데이트는 5세대 Intel Core i5 및 i7 프로세서를 포함하며 Force Touch 트랙 패드를 소개합니다.
1185 질문 전체 보기
MacBook Pro a1502 The keyboard does not work, trackpad works perfectly
I've been asked to try to troubleshoot/repair a Macbook Pro 13" Retina (Early 2015). The keyboard does not work on the thing (except power on/off button) the power on/off button works perfectly besides that when i shutdown the device and try SMS it also works on my internal keyboard, the trackpad mouse does work as well. If I plug in a USB keyboard, that works.  I bought and replaced a keyboard ribbon cable as that seems to be the most common issue causing this symptom, but it has not helped.  I'm really not all that familiar at all with Macbook repair. I tried to connect external usb keyboard . and do SMC and PRAM reset but nothing has changed.
Anyone else have any ideas?  I just hate to spend money on parts that may or may not fix the issue.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
선택된 답변
I’m not sure why you replaced the Trackpad cable here. This series uses independent cables for the keyboard and trackpad.
Lets check the keyboards cable connection on the logic board:
First disconnect the battery following this guide MacBook Pro 13" Retina Display Early 2015 배터리 교체 Follow it through Step 6
Lift the tape which is covering the ribbon cable and its connector:
Carefully! fold up the cable clamp
Now grab the cable and carefully remove it
Now check the contacts are they clean and show no signs of corrosion?
Carefully re-insert the cable back in and fold the clamp back down and reconnect the battery is the keyboard working now?
Update (11/11/2019)
Did you review the video?
Here’s a few snips of the schematics
The keyboard logic in within the logic board not the touchpad (IPD). They do share the same power feed though.
A shorted or damaged touchpad cable could have been an issue but that would have effected both.
Did you inspect the touchpad to see if it has any corrosion?
Did you inspect the keyboard decoder chip?
It’s located on the backside of the logic board, just across from the keyboard ribbon cable.
해당 답변은 도움이 되었습니까?
점수 2
댓글 9개:
Hello Sir, Thx a lot for replying, i have tried this one but has nothing changed. by the way ( The keyboard does not work on the thing (except power on/off button) the power on/off button works perfectly besides that when i shutdown the device and try SMS it also works on my internal keyboard, that means the problem not from my keyboard. Am I right ?
Windows POST and macOS POST are different, so seeing it work under one and not the other is not telling us that much.
Take a look at Louis Rossmann's vid here: A1502 Macbook Pro Retina no keyboard/trackpad fix/repair
Mr. Dan do you think there is an issue in trackpad(which has the logic board that runs the keyboard) ?
Time to replace!
@danj Is it hard to replace by myself ?
댓글 4개 더보기
댓글 달기
귀하의 답변을 추가하세요
Kubaisi 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 43
전체 시간: 2,914
