How to replace the usb type c connector?
I saw the video from a few years ago where Andrew worked with Jessa to replace the USB connector on the Glalaxy S3 but that was a regular USB port
I was wondering if anyone tried to do the same thing with the USB-C type connector
I noticed on the video that it was installed with the soldering iron by soldering the pins to the pad
The problem with the USB-C is that it has 2 rows of pins so there is no access to the inner rows so you can’t use the soldering iron so the hot air needs to be used
The problem I am having is that by the time the solder melts the plastic material that separates the pins starts to melt at a lower temperature so it damages the connector
What is the best way to install this type connector ?
Can this be done with just a hot air station or do I need to preheat it from the bottom maybe ?
좋은 질문 입니까?
댓글 1개
Sta Tus not sure who Andrew and Jessa are but in your case you want to post some good pictures of your board (both sides) with or without USB C connector (as well as your replacement connector) and lets see what you have going on there. Post the pictures with your QUESTION. 기존 질문에 이미지 추가하기
oldturkey03 의
