주요 콘텐츠로 건너뛰기
2016년 9월 16일 출시. Model A1661, A1784, 또는 A1785. 32, 128 또는 256 GB 환경 설정 / 로즈 골드, 금색, 은색, 검정색, 칠흑색 및 (Product)빨간색으로 제공됩니다.
1364 질문 전체 보기
iPhone 7+ random reboots after nand reball
I recently got my iphone 7+ fixed. it had error 9 so i reballed the NAND and after doing so i put it back together after which it worked fine for a day or so.
Now it randomly shuts off and i dont know what to do, i replaced the battery, tried swapping housings nothing seemed to work. It again throws error 9 at me when i try to restore the device in itunes.
Help would be appreciated
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
here are the logs if anyone could take a look and help me, means alot!
LOGS:
https://hastebin.com/ulokunosay.makefile
댓글 달기
답변 1개
선택된 답변
Mostly on that cases that is the fault of Nand. You have to change other Nand and reprogram correct data and fix it.That issues i have faced many times and also solved by this way.
Other point by remove Nand and restore via iTunes which error shows if still error 9 that means the fault of other site.If 4014 error shows that means the fault of Nand.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
where are you located sir?
댓글 달기
귀하의 답변을 추가하세요
Myron. 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 138
