Why is my Soundfreaq sound kick not charging?
After long frequent use, the speaker no longer charging and power light not turning on, cord fits loosely. I opened up and no apparent damage. Suggestions?
좋은 질문 입니까?
좋은 질문 입니까?
@ilovelucy24680 check the charging port for power when you have the charger plugged in. It is possible that the port simply wore out. To replace it you would need to measure it etc. and use that information to try and match one with some ports available at mouser.com or digikey.com. Also, replace the battery while you are at it. Use this teardown to get into it. Use this 기존 질문에 이미지 추가하기 to add your images if you need further help, with your QUESTION.
안내서
난이도:
아주 쉬움
2 - 5 minutes
안내서
난이도:
운영
15 minutes
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 3
30일 전: 17
전체 시간: 1,575
