주요 콘텐츠로 건너뛰기
Repair Guides for HP Desktops.
355 질문 전체 보기
DMI tool for 00A system board error
Is there a HP DMI tool for 00A system board error. Missing product ID info causing aboot up error? I have all this info to enter into something… Thanks
Update (11/17/2019)
Mike:
Thanks for your quick reply. I have an HP Pavillion 510-a010, bought it new in 2016. I will try your solution and I have jumped the CMOS jumpers but that did not work. Is that what you are referring to? I also think the 4 pin molex cables may be an issue but we’ll see. Thank you, Stewart
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
선택된 답변
Unplug power supply.
Press power button until fans stop.
Reset BIOS. You don’t state which HP desktop model.
There is usually a jumper to short to clear BIOS to factory default. Often near Front Panel connectors.
Plug-in power cable and switch on.
How did it go?
해당 답변은 도움이 되었습니까?
점수 3
댓글 2개:
Do not turn on the pc while the jumper is shorted
@captainsnowball Thanks.....Is this the CMOS jumper pins next to the password jumper pin? Andhowdo I 'short it'? And why? HP 510-a010 model
댓글 달기
귀하의 답변을 추가하세요
shaimson7 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 35
전체 시간: 4,902
