주요 콘텐츠로 건너뛰기
3MB 공유 L3 캐시 2.5 GHz 듀얼-코어 Intel Core i5 프로세서 (Turbo Boost 최대 3.1 GHz).
265 질문 전체 보기
Small Spark Coming From Replaced Battery On Late 2012 MBP 13"
Hi, so I recently replace my battery on my late 2012 MBP 13” retina and everything when well. But when I was about to put it all back together I noticed a spark when I pushed down on the battery one more time to make sure the adhesive was stuck good. After investigating I found that I could cause the spark by pressing down on a specific spot right above ssd bay (see picture) but it doesn't happen every time I press. Although I was able to get it spark enough to get some pictures and video. The computer boots and works fine and the battery seems to be working ok. I was just wondering if anyone else has noticed this or if this might be any sort of fire hazard. Thanks for your time and info.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
If you are getting spark then it’s either a short circuit in the connections or the chemicals in the battery are separated by very thin layer and they are coming in contact when they are not supposed to do so. There are many possibilities about why it may be happening. FYI, You could always detach all the sub parts and connect them again and then check whether the problem still persists.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Thanks for your reply. I think you're right about the short circuit. I found where a part of the flat cable that connects the different parts of the battery together was worn just a tiny bit and was sparking when it came into contact with the metal case just right. I added some extra electrical tape to that area and I was not able to recreate the spark. I've run the battery through 3 cycles now and everything seems ok. I contacted ifixit support to see what they thought and they said its probably ok but they decided to send me a replacement battery anyway. This is my first time doing business with ifixit and they really seem to stand by their product.
댓글 달기
귀하의 답변을 추가하세요
Derek Kemp 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 12
전체 시간: 456
