주요 콘텐츠로 건너뛰기
The Panasonic TX-32LX70 is a 32-inch LCD (liquid-crystal display) high-definition television from Panasonic.
Why is my TV malfunctioning?
My TV started displaying different functions by changing the colour mode, volume etc
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개:
Can you post a short vid (or pics) of what you are seeing 기존 질문에 이미지 추가하기
Hi,
Try removing the batteries from the remote control unit and check if the problem is still there or not.
If it stops then there is a problem with the remote
댓글 달기
답변 1개
Hello Badejo
If nothing helps as described in the comments, try the following:
1) Unplug from the wall socket, wait 10 minutes, plug it back into the socket.
2) If this does not help, reset the TV to factory settings (see user manual).
3) If this still doesn't help, consult the service manual.
Good luck,;
Homer82
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Badejo Timilehin 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 8
전체 시간: 243
