주요 콘텐츠로 건너뛰기
The Dell Latitude 7350 hybrid laptop (model number: Latitude 7350) is a 2-in-1 device that functions as both a laptop and tablet. Released in 2015, the Latitude 7350 is no longer being produced. You can find repair guides and device information here.
7 질문 전체 보기
Both USB ports of Dell Latitude 7350 are not working?
I want to install Win 10 on my Dell Latitude 7350 but there is an issue that it could not be installed. As u know there is no CD/ DVD ROM in this laptop, so there is only one way to install Windows which is through USB. But unfortunately, my laptop is not loading/ picking the windows from USB. I think both USB ports are not working. Please help me that how I can get rid of this issue???
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
Check to see if you can charge something through the USB ports, if you can then it’s probably a usb issue or bios won’t boot from it, if they don’t, there might be a blown fuse somewhere
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I think your USB port might be fried, so your gonna need a replacement laptop, or just repair it.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Hi @zeku_ ,
It could also be a setting in Device Manager that stops the USB port supplying power to the connected USB device.
Here's a link that explains it. Read the Chosen Solution USB port on the right side no longer work
댓글 달기
귀하의 답변을 추가하세요
Abid Hussan 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 10
전체 시간: 630
