주요 콘텐츠로 건너뛰기
Repair and disassembly information for the Samsung 55" UHD television with model numbers UN55MU6290xxxx. Released in 2017.
65” Samsung Curved got coffee spilled on it
My TV is actually model UN65MU6500 coffee got spilled on it and now it just turns on and off with a black screen. It acts like it wants to come on then goes back black. And just keeps repeating over and over.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Kyron Perks  at this time you want to stop trying to turn it on. Unplug it and do not use it. The constant on-off attempt can make an already bad situation worse. Remove the back cover from your TV and check the boards and interconnect cables. You should notice any coffee stains etc. you also need to check the top of the panel. that is where the LCD boards connect to the panel via some very fine ribbon cables. Depends on what got “soaked” you may need new power board etc. but we would need to see what your boards etc. look like. Post some good pictures of everything with your QUESTION 기존 질문에 이미지 추가하기
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Kyron Perks 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 4
전체 시간: 180
