주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Asus X53E는 2011년 Asus에서 출시한 15.6인치 Windows 노트북입니다.
Asus X53U doesn't turn on
I found a burned-out microchip on our Asus X53U PBL60 LA-7322P Rev: 1A, but I couldn’t find it on the internet after reading the surfaces of the same components PQ206, PQ701 etc. It looks like 740B BV1HC32 , however, I’m not quite sure without a magnifying glass. Could anyone help to recognise it?)
이미지
이미지
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
선택된 해법
Hi @organicnz ,
I think it could be PQ202 and it’s component AON7408L_DFN8-5, same as PQ206, PQ108, PQ303, PQ305, PQ501 and PQ701. It looks like the capacitors are burned too. If they are defective and you don’t know the PN, measure please, if they are connected to the ground or not, then, let me know.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Huge thanks for the quick response mate I very much appreciate :)
I'd like to order a MOSFET from Aliexpress while looking for a multi-meter lol
Is this one below compatible with mine?
Also, can I use a slightly bigger ceramic capacitors if those are broken as well?
https://www.aliexpress.com/item/32819605...
Hi @organicnz,
I'm suggesting you order the same component as was placed. See https://www.alibaba.com/product-detail/n... or contact electronics shops like RS Components, TME, Farnell or Ges to request a quote.
About the capacitors, if you will place bigger capacitors, it won't be a problem, the SMD capacitors are placed, because of small size and high capacitance. But be careful about the capacitance and working voltage, however, if they are connected to the ground, don't care about the 100% compatibility.
댓글 달기
답변을 추가하세요
Tarlan Isaev 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 12
전체 시간: 994
