주요 콘텐츠로 건너뛰기
2018년 3월에 출시된 Apple iPad 6의 Wi-Fi 전용 버전입니다. 32GB 및 128GB 스토리지 옵션으로 제공됩니다. 9.7인치 레티나 디스플레이와 64비트 A10 퓨전 칩이 특징입니다.
150 질문 전체 보기
Identification of 32 vs 128GB Models?
Is there any way to tell by visual inspection whether you have the 32GB vs 128GB model? I’ve got a surplus one of these without a screen, and am wondering if it’s worth ordering a replacement screen for it or not. I looked up the serial# at Apple Support, no luck there.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
Yeah, was hoping for a way that didn’t involve tearing it all the way down to the iron, but it looks like no dice, huh? As for the size, it’s more that the 32GB can’t really be of much use to us for our organizational needs, while the 128 definitely would be. Thanks for the info!
댓글 달기
답변 2개
선택된 답변
I think another way is to open it up and access to the NAND flash
from there you can google the part no for the capacity
https://pasha4ur.org.ua/articles/difdevi...
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Jared Dunn it would not matter what capacity your iPad is since both have the same LCD and digitizer. So looks like current new replacement price for a 32GB is ~$280 USD and the 128GB ~$380 USD The digitizer and the LCD will cost you around ~$180 USD on iFixit but can be had for 1/2 that cost at other places (most likely lower quality and warranty). So, add that to the cost of your iPad and see if it works out economical. Once you have the display replaced, you can determine the storage etc. via the iOS software. Only other way is the one that @salmonjapan described, by identifying the NAND.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Jared Dunn 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 4
전체 시간: 46
