주요 콘텐츠로 건너뛰기
Repair guides and disassembly information for the MacBook Pro 16'' released in November of 2019. Model A2141, EMC 3347.
211 질문 전체 보기
Airpods pro range got worse
Hello,
Until yesterday, I had a Macbook Pro 13” 2018. Paired to it, the Airpods Pro. I was very surprised that the headphones worked not only in the openspace-office, but also in the workshop which was at ±25m (air)distance and separated by a concrete wall. Today I switched to the new Macbook Pro 16”. The positive surprise from yesterday turned into a very negative one: As soon as I’m at a distance more than 10m from the notebook, the music cuts. Same application, same software configuration (Migration assistant), only new MBP. Does the new MBP have a much weaker bluetooth antenna, or “what the range” happens?
Thx in advance!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
Just looking at the teardown between the 2019 16” and the 15” models you can see there is really no difference in the antennas
2019 MacBook Pro 16”
2019 MacBook Pro 15”
Looking at the logic boards we can see a slight difference! Light Blue marked chip Wi-Fi/Bluetooth module
2019 MacBook Pro 16” - 339S00610
2019 MacBook Pro 15” - 339S00458
While the chips them selves have different markings, as these are custom chip we just don’t know what’s different inside.
Both list WiFi 802.11ac & Bluetooth 5.0 support so I can’t see a reason to alter the WiFi/Bluetooth transceiver chip.
So… I would double check another system to see if you got a bad one. The antenna cables could be damaged or could have been connected incorrectly.
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
Hello, Dan
Thanks for your response. Today I was with both notebooks to the Apple Service. Showed them the phenomenon. Answer was “it’s normal that the range is 7-10m, as bluetooth is working at this distance”. I showed them that the old one is working at a much higher range and showed them your suggestion. They opened the new MBP16, checked antenna connection, said it’s correct, and again reassured me that the range should not be more than 7-10m. Therefore…it seems it’s the old MBP’s “fault” to wok at that big distance. And no, I havent been with it to Chernobyl :)
With the 10.15.2 update (build 19C57), the problem seems to be patched and the range is the same as with the old MBP.
댓글 달기
Running MacOS 10.15.6 and still have bluetooth range issues….
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
danms84 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 16
전체 시간: 1,051
