My speakers stop working no sound coming out of mypioneer mvh- "x365bt
There's no sound coming from any speakers checked fuse fine and wires fine unit has power no error message checked all source's radio,aux and bt
좋은 질문 입니까?
좋은 질문 입니까?
have you got an different stereo, maybe the original one to try, if you have plug that in if the speakers work then the issues with the inside of the stereo most likely, if they don't I would try checking the harness and any adaptors that have been used to connect the stereo first.
해당 답변은 도움이 되었습니까?
Testing the speakers and their wiring harness is easy.Connect the speaker jack into the two ends of a small 1.5V battery(AAA) to hear the sound of a healthy speaker from the speaker. Disconnect the speaker jack from the "Pioneer mvh- "x365bt " first.
Quickly connect the wires to the battery and disconnect them immediately and repeat the operation several times to hear sounds like a knock from the healthy speaker.But only use AAA battery 1.5 Volts.
I had the same problem.
New pioneer deck, then new dash speakers.
A few days later, new rear speakers in the back.
Shortly after, all sound was dead but the radio looked like it was working from all inputs.
Turns out the rear speaker wires were touching the metal of my car that surrounded the speakers. I rotated the speakers 180 in their holes and that kept the metal tabs of the speaker away from the car body and sound came back.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 15
30일 전: 57
전체 시간: 1,154
Hi,
Does the unit turn on?
Did you try different input sources e.g. aux or BT to check if there is audio when using them?
Is there an error message on the screen?
What else have you tried besides checking fuses and wired?
jayeff 의
Head unit turns on fine no error message speakers just stop one day all four at once
cecildew 의
Hi,
Did you try other input sources?
jayeff 의
Tryed other sources aux,radio and bt but no sound coming out of any speakers
cecildew 의
Hi did you get problem fixed? Having same problem. I did not put a different stereo in. Was working fine.
Cheers Donna
Donna P 의
