주요 콘텐츠로 건너뛰기
모델 A1013, A1052, A1085, 또는 A1107 / 1440x900 스크린 해상도
Boots from battery, but not from adapter
Replaced the DC-in board. As soon as I plug in the adapter, the menu bar says "Not charging". It is not an adapter problem - I use the same as the one for my same unit. Logic board?? That would be a shame, since everything else works.
Something did change when I replaced the DC-in: when I press the power button I hear some sort of sound for maybe 2 seconds, as if it were trying to boot, but the sound dies, and pressing the button again does not repeat the sound, until I unplug the adapter, re-plug it, the sound returns on the first press. So it looks like it is getting power from the new DC-in board?
Then I had this thought: Can I do some soldering and make the computer think the adapter is the battery?
Update (08/12/2011)
Don't know how I can add to my answer to my own post? When I submit without typing anything here, I'm told that this field is required and won't let me submit. When I submit with this field filled in, I'm told that I can't answer my own question??
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Try switching the DC-In board to the other machine to verify it.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
I can't, took the other unit apart. But I do hear a sound with the new DC-in / see my updated post. Any suggestions?
댓글 달기
답변을 추가하세요
sieg deleu 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 10
전체 시간: 444
