주요 콘텐츠로 건너뛰기
Nintendo Switch/닌텐도 스위치는 도킹 스테이션을 통해 TV에서 플레이하거나 이동 중에도 플레이할 수 있는 휴대용 게임 콘솔입니다. 2017년 3월 3일 출시되었습니다.
Missing resistor near charging port
Hi.
Sorry if this has been asked before or if I'm posting in the wrong section.
Just wanted to ask if anyone can tell me what the 2R2 634f is what the value of the resistor near next to it is. I've circled them in purple.
Pic attached.
Thanks
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 3개
가장 유용한 답변
It is a Signal Transformer, some call it a power inductor. The one you need is part # SCIHP0420TB-2R2
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
Thanks Ric. Would you happen to know the value of the resistor next to it?
댓글 달기
2R2 634F is NS motherboard power inductor Big coil components check this http://egamephone.com/index.php?rt=produ...
이 답변이 도움이 되었나요?
점수 2
댓글 3개:
My switch stopped charging, the battery was draining, and the charging symbol was there, but the battery kept draining. I bought a battery to replace the old one, and when I opened up the switch, this piece was just laying there. What would cause it to break off, and is this the reason my switch isn’t charging?
@Michael - Same here. Came in not charging or powering on. Powered up with an new battery and would charge if the battery had some juice. Would not charge a dead battery though. I noticed the 2R2 inductor had come undone. Soldered another one from a dead Switch mobo and it works fine now.
@ACE How did you manage to solder another inductor on with the pads on the underside? Did you have to use hot air?
댓글 달기
There is no photo attached.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Sorry must have missed it. Its uploaded now.
Thanks
댓글 달기
답변을 추가하세요
email ko 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 4
전체 시간: 1,960
