주요 콘텐츠로 건너뛰기
Samsung's wireless earbuds. Released in March of 2019 with the Samsung Galaxy S10 phones.
40 질문 전체 보기
HELP:My earbuds come up as two separate Bluetooth devices- How to fix?
How can I Force the two earbuds to sync up and become one Bluetooth device?
They are coming up as two separate Bluetooth devices in settings and I can only connect to one at a time.
Is there a way to force reset them?
Disclaimer: I cannot Reset through the app as that only works with two of them connected. Right now I'm the wearables app there are two separate devices.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 39
댓글 38개
i have tried resting my earbuds and disconnecting them but they still show up as different devices. i use a galaxy tab A (8.0 2019) samsung tablet. nothing is working and this is a newer pair because only one earbud connected with my last pair. please help T^T
I had the same problem. Optimum T21 earbuds only worked 1 at a time. Your solution fixed the issue. Only thing is that I am no longer getting stereo that I got before. The update may have been a good idea to have 2 seperate devices but the issues were not thought through.
I have the TCL MOVEAUDIO S150, at first, it showed as one device but somehow I made them into two separate devices now, Idk how to fully reset since it doesn’t have any button to do so. Any help would appreciate it.
This is a phone issue...
What happened with me is...
I used one bud at a time...I noticed my phone audio in setting equalizer to Jazz
Other was to custom
I made bothe default one by one....and that it:)
kayla sims comment worked for my "chinese" ear buds as well, thank you
댓글 33개 더보기
댓글 달기
답변 20개
선택된 답변
I have returned to Samsung for a free new pair, as covered in my warranty. None of the other solutions have worked and support representatives told me this was the only option.
해당 답변은 도움이 되었습니까?
점수 6
댓글 16개:
FOR THOSE PEOPLE WHO WASNT ABLE TO CONNECT BECAUSE OF TWO DIFFERENT BLUETOOTH ADRESS check this out it worked for me both of my buds working good now https://youtu.be/hmHVWegdhjU
@adel_hussain00 Thank you!! I have been trying to fix my ear buds for the last two days! Your post is the only advice that has worked. Thank you
Wonderful advise. It really works
I have an iPhone 12 Pro with the same problem. One will come on but not the other
Can anyone tell me how to do the same with Tecno Hipods H2? I have this problem for a long time.
댓글 11개 더보기
댓글 달기
가장 유용한 답변
hey, this works for me so hopefully will for you. If 2 different things come up for your bluetooth headphones and won’t connect at the same time, do this:
put earphones in the charging case.
click ‘forget this device’ on the bluetooth.
take earphones out and turn on bluetooth.
triple click (click 3 times) on the left earpieces control pad to re sync the earphones as one bluetooth device.
(it should now show up as one device in your bluetooth instead of 2)
hope this helps some people.
해당 답변은 도움이 되었습니까?
점수 37
댓글 35개:
This worked for me, thanks
Thanks so much this worked for me!
thank you so much. worked for me
Thank you it worked....... such a relief.....
This worked for us also
댓글 30개 더보기
댓글 달기
I've just had the same issue.
My left was showing as (1800) and my right was showing as (7C3E).
What I did was reset both. Placed both in the case and closed it.
I then opened and placed my thumb so it was touch both bud touchpads.
Wait until the centre light in the starts flashing on and off with a green light and try and re-pair the device.
Worked first time. Let me know if that helps.
해당 답변은 도움이 되었습니까?
점수 22
댓글 32개:
Thanks Buddy. It worked for me. Perfect!
This solution worked for me. I could connect both, but separately. With the 5 second holding down the touchpad they finally both connected at the same time.
Yes worked! Thank u
It's worked for me too. Thanks!!!
Hi I don't completely understand the instructions. Can someone please explain to me in a simple way. Thanks
댓글 27개 더보기
댓글 달기
This has been frustrating me for a long time but I have found a solution, which may or may not work for you, depending on your earbuds touch controls. The solution which worked for me was to tap each earbud 10 times until the blue light was constantly on rather than flashing, then placing them in the case and repeating a couple more times before they paired and showed up as one device.
I hope this can help some of you.
해당 답변은 도움이 되었습니까?
점수 7
댓글 5개:
It worked bro.. thanks. I tapped the reset button multiple times and it somehow combined them as one connection.
Thank you SO MUCH I’ve been searching for solutions for like an hour and yours finally worked
Thanks it worked
It really works..not sure how though😅..Thanks bro.
I had tapped more than 10 times on each
Finally it works. Thanks!
댓글 달기
THAT IS THE #1 solution I have found, take them out case and double tap one of them they are then paired, turn Bluetooth back on connect bang both work !!! Top top advice that is
해당 답변은 도움이 되었습니까?
점수 5
댓글 1개:
it worked for my sentry bt696 thank you so much.
댓글 달기
Hi,
Try resetting the earbuds by inserting the earbuds into their corresponding slots in the charging case and remove them after 10 seconds or more.
Just verifying that you have the earbuds in their correct position in the charging case when you go to pair them with your device?
Here’s a link to the user guide which may also be of some help.
해당 답변은 도움이 되었습니까?
점수 4
댓글 8개:
all that does is turn them off and on and does nothing to solve the issue
I've just had the same issue. Type: Buds R170
My left was showing as (6809) and my right was showing as (15EE).
[image|2336472]
HELP ME
Thank you umaru yang..it worked!
Thank you sooo much Umaru!!
댓글 3개 더보기
댓글 달기
Put your earbuds in the case then take them out. Since both of them show as different device in your phone, they'll both blink together. Press the left earbud twice. Then you'll observe that only one of them is blinking. This means they are now connected as one. Turn on the Bluetooth in your phone and pair the earbuds.
Hope this helps!
해당 답변은 도움이 되었습니까?
점수 1
댓글 3개:
THANK YOU! Finally found something that worked for my Bluehive earbuds.
Yupp this worked!!! Thank you
Model : TAGG Rogue 200GT
Omg thank you so much!!! This definitely works after weeks of trying to find a solution. Thank you again.
댓글 달기
I found a fix that worked for me!
First make sure both buds are unpaired and put both back in the case. Then pull them back out and make sure both lights are flashing blue, then double tap one of the buds - usually the left one works best - and the other's light should turn off. Refresh the Bluetooth list on your device to make sure there is only one connection showing then hit pair!
Hopefully this isn't too confusing!
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
While paring the device remove both the buds from case and make the device available for pairing
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
I want to add to what everyone has.
I lost my right earbud and replaced with used one.
To fix this make sure both earbuds are connected separately.
Than update each earbud the newest firmware so that you can match firmware and connect both together.
This worked for me it automatically synced both but didnt work previously.
How do you Update each separately?
댓글 달기
I have bluehive BluePods Iso from Canadian tire. (Feb 21,2022) I tried many different things to reconnect them together but always had 2 separate earpods. I finally put them in the case. Closed the case. Unpaired them from the phone. Opened the case. While they were still in the case tapped the one earbud quickly 3x. This paired them together again. Thanks to whoever suggested the 3 quick taps while they are in the case.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
I have BlueHive Iso from CAD Tire as well, with the same. I checked the instructions and was able to successfully fix the issue as follows: 1) disconnect the buds from your phone, 2) turn them both on (in your ears), 3) tap either one 3x times. You will hear a simultaneous beep in both buds. They should be paired to each other at this point.
댓글 달기
I have F9-bth-01 earbuds.
I've tried all the resetting steps I could find, but still it keeps showing as 2seperate devices.
What to do?
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
I have a new set of replacement buds, (the first set wouldn't pair) that I'm using with gz3 flip. My phone can't see the buds so they don't appear on the list. I'm counting on its not possible to have two sets fail, ...is it?
댓글 달기
First unpair bud(s) with phone. Press both ear buds for the same time for 40-50s when they are on your ears. After 20s the LED'll turn off, but after 40-50s it'll come back for a short time, wait for it. You'll hear different voices. Then took them back in to the charging box and turn them on in the box, they'll find each other. Now get them out and scan bt on the phone. You'll find one bud, pair it. Open any media and enjoy listening with two buds.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Kayla Sims
Thanks...
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I haveTWS TG02 i try all things to make both sides work together , put still show as 2 separate devices
Any chance to make this right?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
  • Start off by unpairing both ear buds.
  • Put them back in their case
  • After 5 seconds, take both of them out.
  • Tap 10 times on each of the earbud.
  • The blue lights should start synching.
  • Connect with bluetooth and it should work fine.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
I tried this and they wouldn't connect to my phone at all
댓글 달기
I have the fix for it!
I contacted customer service yesterday. It took 9 hours but the helped me eventually. They told me to pair my galaxy earbuds plus with my phone. (You have to pair each earbud with tour phone, if you are seeing it as 2) and then you have to leave them in the case and then open the galaxy wearable app. After that you have to find the find my earbuds option and then you have to leave your earbuds in the case and let the make noise for a minimum of 30 sec. After that they should work. If this doesnt contact customer service
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
I have a nypots a8 and it showing up as different buds does anyone with similar earbuds have an idea on how to fix
댓글 달기
Basically what u do connect ur right earbud and turn of ur left one then turn it back on and enjoy
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I plugged my earbuds to an outlet and recharged it and it worked. Let me know if this was helpful ☺️☺️
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
For R 50i Anker sound core airpods troubleshooting about pairing of two buds together see the below you Tube link :
https://youtu.be/wTZ3e6amFJM?si=eCUV9Frh...
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
i have QCYT17 earbuds . i solved this problem by put earbuds in their case. turn off Bluetooth and forget device. touch both for 10 seconds . problem solved with The white light flashes.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Max Shal 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 413
7일 전: 2,645
30일 전: 11,533
전체 시간: 373,029
