주요 콘텐츠로 건너뛰기
모델 번호 A1238 / 80, 120, 또는160GB 하드 드라이브 / 검정색 또는 은색 금속 외형
904 질문 전체 보기
How to make the back fit more tightly
I have repaired and upgraded many iPods, mostly 5.5G, but a few 4,5,6, and 7. I have been buying aftermarket backs and find (as one might expect) that the specifications are a little loose. I am currently working on a 7G, but I expect that my question is equally applicable to 4-7G since the backs attach basically the same way. When I reassemble the case, it is not coming together tightly, so the seam is not tight. Before I “trial and error” it, I thought I would ask the question here to see if I can start with the best method.
I tried bending the flanges out slightly. No improvement. Is there a difference between the backs of a thick 5G and thick 7G? Otherwise I think it may be just a sloppily made back. Thanks for any assistance.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
@lingenfr “difference between the backs of a thick 5G and thick 7G? “ yes there are. The spring steel that makes up the “flanges” that will hold the backs to the midframe is different. The sloppiness is most commonly caused by misaligned and compressed spring steel “flanges”. You may have to adjust those by increasing or decreasing the distance from those to the actual cover.
해당 답변은 도움이 되었습니까?
점수 4
댓글 달기
귀하의 답변을 추가하세요
Rusty Lingenfelter 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 59
