Why won’t my Hoover power on?
Hoover vac completely dead…. won’t power on. Outlet is in good working order. Is there a fuse on vac I can replace? Bad switch ?
좋은 질문입니까?
좋은 질문입니까?
madmom1256 no fuse on your vacuum. Sounds like either a bad switch or bad wire. Use a multimeter and check if you get power to the switch. If you have trouble with the disassembly etc. Let us know your Hoover’s exact make and model number.
이 답변이 도움이 되었나요?
I have a Hoover power dash pet it has a bad power switch...how do I replace it?
Mine also will not power on . Only use it a couple times a year .pretty new yet. What are my options?
@Shari-Dee Revilla what make and model is yours? What have you checked?
I also have a Hoover Power dash pet. I’m having the same problem with my power button or wires. This sounds like a recall on these for the power switches. That’s all I see when I look this model up FH50700. Thousands of people that have bought this model all is having power switch problems. Please help how to fix this problem. It would be greatly appreciate it thank you
Mine is also having the same problem WTF should I do I have no receipt or box help
I bought my Hoover pet cleaning machine a year ago worked Great 5 times getting up spots but it made aloud noise brush still rolling and got a smell of wires or belt burning to where my fire alarms went off and now will not start back. What do we do? To all the comments it look as if there is a lot of complaints with the exact problem. They should be recalled !’n
이 답변이 도움이 되었나요?
I need my money back
I bought 2 , same issue aqd you only after 3 uses....
Same! I bought two and they BOTH died after minimal use, but after the warranty period. Moving to Bissel.
I'm experiencing the same issue as well with model # FH50710
Just got mine and it won't turn on I mean it's just like totally dead it's still clicks like it's trying to turn on but nothing so I'm thinking fuse h u h
You should try to re-solder the switch. You can take it off by unscrewing the screws in the handle and if the solder joints are fine then try to replace the switch.
이 답변이 도움이 되었나요?
I am on my second Hoover Power dash pet. Same thing as first one.
Works fantastic then motor makes a loud sounds( roller still moving).
I smell a faint hot electric or belt smell.
It will not turn on.
I dont have the income to buy another..help?
Used my carpet cleaner 2 times, on living room area rugs and now it won't turn on. This seems to be a problem with this product and it needs to be put on a product recall list. I never have liked Hoover products but I thought I'd give this carpet cleaner a try, what a mistake that was! It didn't even clean my rugs very well at all. Piece of junk. No wonder it was on sale, got it at Wal-Mart for $79. dollars.
@kathyawalters Seems like the motor has gone bad. You can order a replacement motor. Just look up the model number followed by replacement motor. You can find a replacement guide on the internet.
If all our mothers went bad hover owes us all money since I am not getting answered how to fix it
@kathywalters same. Exact. Ordeal. My sister had the power dash pet blue & white model(which was then the cheaper model. Worked fantastic.one day foul smell then left adark streak simultaneously. It was shot. Couldn’t turn it on without it burning up.bought the same cleaner,as again it cleans great WHEN it works.purchased the grey model,not sure how tho seeing as i 110%know i purchased the SAME vac shown theyre the same,slightly different this point im assuming its just the colors were different why?cuz it 110%said “ purchased 1 time “ right above it in my walmart app.it worked great, it had the super long attachment (which i never got to use btw) unfortunately I couldn’t afford a warranty at the time.noticed it had”heat force”technology near the attachment plugin.out the blue starts loud noise&stops.this time I can’t get it to turn on.looks like spring in red foot turn on button is broken,(anyone have this issue? Did you buy the assembly and did the fix work?
I just removed my red toggle switch from my Windtunnel 2, which stopped operating. Low and behold, no continuity in the on or off position. It may also be related to the flash of light I saw at the switch when I tried to start it as usual. Don't try if you aren't sure what I am describing, but I intend to wire it with a heavy gauge copper wire and use the outlet for the time being as the on-off switch until I can find a replacement. (Guests are coming over tomorrow and it's late:)
Update: Removed the rubber insulation from both (detached) leads into the switch. Sandwiched them together and held in place with a small, plastic clamp. Plugged in, and ran for 30 seconds. Unplugged, checked for heat or smell, none. Plugged in and ran for 2 minutes. Still functioning properly. I'll find a replacement switch tomorrow, but I'm not paying a professional $120 to replace a crappy switch. Don't try at home.
이 답변이 도움이 되었나요?
I got mine to work by slamming the power button, will just unplug it from now on
이 답변이 도움이 되었나요?
I bought mines a few months back and used it twice. I was using it today for the 3rd time. It did start up cleaned a small area went to empty the tank came back to not even wanting to turn on. I did all I can do to try and fix it. As I read the comments I see that Hoover has a default in this product however, they would like for the customes to try and solve a problem.
This product should be recalled back to the manufacturer. I know I will be posting about this product on all my social media platforms. It's just not worth other people losing their money and having to go through the same thing we are experiencing.
이 답변이 도움이 되었나요?
Experiencing the same issue, used afew times, sat for 6 mo and went turn on.
이 답변이 도움이 되었나요?
@kimlamb we may just have a good answer for you but we do need to know the exact model for your Hoover. Also, what have you checked and what have you tried?
FH51010 TYPE MENA STICO SERIES/SERIE SERIC 120 v. 60Hz.
Got pwr to the switch and the switch is fine, belt is broken, still no power to motor.
지난 24시간: 10
지난 7일: 73
지난 30일: 407
전체 시간: 27,951
댓글 11개
Same problem, mine was used 3 times and stopped turning on.
Jessica Boyd 의
It would be nice if they would either recall or replace these
Jessica Boyd 의
I didn’t see this when I checked for reviews.
I’m also having same problems
Traci Colomb-Farmer 의
Ok people, like everyone else, I have the same problem with my Hoover Power Dash and I almost was ready to throw it away! I had it outside for a year and after reading everyone’s comment, I decided to clean it up and try to power it. I used the plug outside the house 120v and Holy Smokes it power up!!!! When I tried to plug it in inside the house, no power! What does this mean?? I don’t know but I tried it on every plug in the house and no power. Only work with the extension cord plugged from outside!!!
Update from 4/21/22
Antonette
T Petitt 의
I have the same issue , used it only 3 times
wolfie53077 의
댓글 6개 더보기
