주요 콘텐츠로 건너뛰기
Repair guides and support for your Samsung TV.
Need help with SMD resistor equivelant.PS42Q96HD
I have this PS42Q96HD SAMSUNG TV WITH A SMD RESISTOR MISSING ON THE POWER BOARD B44-00194A
( with 302 on top in position rs828 on board which says it is 3kΩ ± 5% ),
And i am wandering if i could use another with higher rating As mine is missing if so what could i use meaning either number on top or the amount of ohms I am showing on picture the position on the board as it is missing
Thankyou in advance guys
Update (01/10/2020)
Hi Jayeff Sorry for not explaining correctly Its just i have loadsa various psu boards and wandered if i could of used another smd to replace the one marked 302 on top as in pic as they don`t have that on on them.Would just need to know the number on top to see if ii have a one that would do same job properly,Thnx.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi @moggy01
What do you mean by rating?
If you mean power rating that is not a problem.
If you mean the resistance value, I wouldn’t stray too far away from the specified resistance value as its’ value was selected, in conjunction with RS827 and that of the opto coupler, to set the required base voltage level for QS807.
It already has a low tolerance value of 5% so the circuit designers didn’t want the resistance to vary more than between the range of 2850 - 3150 Ohms.
Here’s an image taken from the schematics for the board.
(click on image to enlarge for better viewing)
이 답변이 도움이 되었나요?
점수 1
댓글 3개:
Hi @moggy01
Either find a resistor with 302 marking or use an Ohmmeter to measure the resistance if you are unsure.
I'd measure the resistance of one marked 302 anyway just to make sure that it is 3000 Ohms give or take 5%
Hi JayeffI will thnx
Well got sick of trying with the board i couldn`t sort it so got one off ebay but Thankyou for all the help.
댓글 달기
답변을 추가하세요
moggy01 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 137
