주요 콘텐츠로 건너뛰기
Repair guides and support for your Samsung TV.
2612 질문 전체 보기
Samsung UN60JS7000 turns on, but no picture (sound works)
Samsung UN60JS7000 turns on, but no picture (sound works). Flashlight test reveals no picture. When I disconnect the ribbon cable between main board and t-con board, the backlight comes on. Interesting…Any ideas?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Clinton Hughey since you do have backlight but no picture shown with the flashlight test , the issue appears to be a main board issue. There is always a chance that this is also the t-con board or the main panel (unlikely) Start with the least expensive one first. (T-con then main board)
해당 답변은 도움이 되었습니까?
점수 0
댓글 3개:
Thanks oldturkey03 !!!
Update
Tried replacing T-Con board - No Dice
Tried replacing Main Board - No Dice
Any further luck on this issue? I am facing the exact same problem.
댓글 달기
귀하의 답변을 추가하세요
Clinton Hughey 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 141
