주요 콘텐츠로 건너뛰기
모델 번호 A1238 / 80, 120, 또는160GB 하드 드라이브 / 검정색 또는 은색 금속 외형
904 질문 전체 보기
Why my logic board died?
Hi all,
Here is mine: a couple of weeks ago I found back my old 6th gen Ipod classic, I put aside few years ago because a dock connector pin was bent, the ipod was unable to sync. But it still could charge and play music.
I decided to revive it, and bought a new connector. Waiting for it I started to gently disassemble it. Then I succeed to unbent the pin.
But when I reassembled it, it did not power on, neither be recognized by my computer or charge.
I did not hear any HDD sound.
I checked the battery with a multimeter and it is ok.
Then it should be the logic board?!
How could it be?
Is there a way to be sure it is dead?
If some battery connector was damaged the computer would recognize it, wouldn’t it?
Thank you
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
Thank you oldturkey03, I’ll order some new, I noticed there are several with the same reference (616-0230) but different intensity, no intensity is written on my battery. What would it change if I put a different one? The total capacity?
댓글 달기
답변 1개
가장 유용한 답변
marottabruno  go ahead and replace the dock connector. This sounds like broken or shorted pins since this started after you straightened the pins. BTW checking a battery with a multimeter is very unreliable since the battery may fail under a load. When in doubt, replace it.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
marottabruno 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 7
전체 시간: 122
