주요 콘텐츠로 건너뛰기
Apple's fourth-generation smartwatch, with optional cellular connectivity, released September 21, 2018.
124 질문 전체 보기
Torn ribbon ground replacing screen. See picture..
Is there a way to repair the ribbon after it has been torn? It is the two outer ribbons that seem to be grounded to the chassis.
Can this be repaired or do I need a new ribbon assembly?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 4개
선택된 답변
I actually put it back together as is and it’s working fine. I have no idea what they are for but they’re not affecting functionality as yet.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Is your watch still working ok. I just tore the same cables?
Thanks
댓글 달기
Yes it can be repaired with the right tools and experience. Short answer, no don’t waste your time. Time is money and that part is 50x cheaper to just replace instead of spending hours to fix.
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
I have been searching for a source for a replacement "ribbon ground", but can't find any :-o
Does any of you know of a good source and a link to it?
Thanks!
댓글 달기
Will it make a ometv chatroulette  chat avenue   difference if I use the original cable? Thanks
해당 답변은 도움이 되었습니까?
점수 -1
댓글 달기
++https://ometv.vip/++
++https://bazoocam.live/++
++https://omegle.monster/++
++https://chatzy.xyz/++
++https://ometv.icu/++
해당 답변은 도움이 되었습니까?
점수 -1
댓글 달기
귀하의 답변을 추가하세요
canicoll 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 22
전체 시간: 828
