주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Wi-Fi 전용 버전의 Apple iPad Air(모델 번호 A1474)입니다. 스페이스 그레이 또는 실버 색상으로 제공되며 맞춤형 A7 프로세서가 탑재되어 있고 16, 32, 64 및 128GB 용량으로 제공됩니다.
Battery drain with LCD connected
Hello there, I have a problem with iPad air 1. It is a little bit strange but when I plug LCD it drains battery.
Example: Yesterday I charged it to 100% and I didn’t use it at all, today battery is dead so I disassembled iPad and started to look for fix.
I plugged in a power supply to check if it takes any power and with board taken out of ipad when I connect only board to power supply it takes 0 Amps but when I turn off PS and connect LCD it takes 0.15A just with plugged in LCD, battery cannot be charged because of this drain and I have to charge battery with LCD unplugged. LCD is not a problem because I’ve checked with 2 others and problem is same, something is taken 0.15A out of battery constantly when LCD is plugged into board.
Do you have any suggestion what can cause this kind of problem ? Thanks a lot for any help
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
A 0.15A draw should not impede the charging of the battery. It doesn’t sound normal but I’m having a hard time visualizing your test setup.
Fully charge the battery with a DCPS (be careful, there are videos on how to do this safely) or install a good replacement battery, loosely assemble the device and see how it responds. You need to determine if this is a battery/charge issue or an LCD driver issue.
Get back to us with more details.
이 답변이 도움이 되었나요?
점수 3
댓글 달기
답변을 추가하세요
sofles 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 4
전체 시간: 86
