주요 콘텐츠로 건너뛰기
모든 종류의 배터리 수리 안내서 및 지원.
74 질문 전체 보기
replacing lipo cell with a lipo, same c rating but slight lower capaci
I have a 3S 35C Goldbat Lipo 2200mAh battery that fried one of its cells. I have a lipo that has the same c rating but instead of 733mAh( I divided 2200mah by 3 to get 733mah a cell) it has a capacity of 650mAh. I know that it will drain slightly quicker than the other cells, but can it work?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
@fegelein by using different cells you’d be changing the parameter of this battery. That in turn could potentially mess with the existing protection circuit modules parameter. You’d be risking over-charging/over-discharging and the ultimate would be if your battery will vent-with-flame. As you can see, not a good idea.
It’ll be much safer to spend the USD$30 and get a proper replacement
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Brayden S 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 4
전체 시간: 52
