Turned it on and screen is black BUT can see screen with torch?
Turns on ok but screen stays black but can also hear sound
좋은 질문 입니까?
좋은 질문 입니까?
hassananany3 depending on your exact model. This is usually related to either a bad T-con board, bad power board or bad backlight array. Measure the voltages on the power board at the LED connector and see if the voltage is consistent between each other and what maybe printed on the circuit board. My money is on a bad backlight LED strip but check things out first.
Post the exact model number with your question as well as a few good pictures of the power board if you need to know which connectors and what voltages to measure. ++++기존 질문에 이미지 추가하기
해당 답변은 도움이 되었습니까?
99% bad led strip. Would be best to replace full led strip set. Hope it helps
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 4
30일 전: 8
전체 시간: 70
